cfc999
| posted on 20/10/17 at 08:33 AM |
Digital dash
Can anyone recommend (or does anyone have) a budget digital dash for my zx9 powered sprint/hillclimb striker.
It's not for the road so I only need basic info the two main ones being revs (for noise test) and gear selection/neutral. Oil pressure and water
temperature would be good too. Must be waterproof and easy to see. Was planning on using the bike clocks but just weighing up my options before I cut
a hole in my dash.
Bunje
| posted on 20/10/17 at 08:38 AM |
depends ho much your looking to spend but i have the etb digidash 2Lite i think it is great bit of kit for the money all sensors included. does abit
more than you need so may be out of your price range
russbost
| posted on 20/10/17 at 09:11 AM |
If you don't need speedo, but want bomb proof reliability at a budget price then get the Acewell 1100
LINK
If you talk to Oliver at Furore Products you'll get 5% off the web price info@furoreproducts.co.uk or furoreproducts@hotmail.com
[Edited on 20/10/17 by russbost]
jossey
| posted on 20/10/17 at 09:32 AM |
Same as Russ suggests he got me to get one of them for track days.
But I then bought the 1600 for IVA both from furore as we get 5% as locostbuilders.co.uk members.
Great customer service too.
[Edited on 20/10/17 by jossey]
David Johnson
cfc999
| posted on 20/10/17 at 09:38 AM |
Thanks for the replys guys. Yes the Acewell looks like the type of dash I'm after. I'm running a old pro shift actuator gear change system
with buttons on the steering wheel so could do with a digital display indicating which gear I'm in.
jossey
| posted on 20/10/17 at 09:52 AM |
https://www.solomotoparts.com/HealTech-Gear-Indicator-Pro-X-Type-for-ZX9R-98-03/
Get a gear indicator. Don't know of many low end cost speeds with gear indicator on them to be honest. Koso used to do one but I'll never
use them again. Chinese crap. Although I hear they now have a UK disti my issue was 4 months for a return and refund and then the wouldn't
refund the postage cost back which was £50 and the purchase postage which was £30 so actually I paid £80 for nothing plus the refund took 4 months.
David Johnson
russbost
| posted on 20/10/17 at 10:20 AM |
Ace 3252 does pretty much everything including gear indicator, for change out of £125 I can't see how you can buy better! It even has a pretty
yellow display!
LINK
[img]
  Acewell 3252
[/img]
cfc999
| posted on 20/10/17 at 12:57 PM |
Ok thanks for info. Could run a separate LCD gear indicator to keep costs down. My eyes arnt that good so could mount it in my line of sight slightly
higher up .Seen them on fleebay starting around £12. Anyone used one.
jossey
| posted on 20/10/17 at 06:41 PM |
That dash above looks good. I'd have got that. I'm about to swap out the zetec for another bike engine
David Johnson
ragindave
| posted on 20/10/17 at 08:44 PM |
Try one of these!
1pc LCD Digital 15000rpm Dual Motorcycle Speedometer Tachometer Odometer Gauge
Phil_1471
| posted on 21/10/17 at 07:12 AM |
The £12ers from Ebay arnt great in my experience. I have one, depending on what mood it's in depends on if it chooses to reset its neutral
position. So means sometimes starts counting from G1 or N. wouldn't waste your time or money on them, by the time I gave up trying all sorts to
get it to work I realised I didn't need it as got used to knowing what gear I was in by feel.
You can live in a car but can't rally a house
russbost
| posted on 21/10/17 at 07:41 AM |
There's a big difference between cheap cr*p & a quality product at the budget end of the market! In all the years I dealt with Acewell I
think we had about 4 faulty units, the fail rate was less than 0.5%! Plus you could still get parts & service for dashes that sometimes
weren't in production anymore!
cfc999
| posted on 21/10/17 at 11:16 AM |
Thanks for the info. My car is going in to have a loom fitted at my friends bike workshop over the next month. He's a bike tuner by trade and
does a bit of racing. He thinks the best option is to wait and see what we're actually dealing with engine sensor wise before buying. In his
opinion he thinks I need 3 things on a budget race dash . Revs, shift light and gear selected indicator. The shift light needs to be in line of sight
when looking at the road and as bright as possible. Don't think I'll bother with the cheap stuff from China and will definitely have a
good look at the acewell range. Will give pro-shift a ring and see what they recomed using on their race gear change systems.
