Author: Subject: cbr vs GSxr1100
farmboy
posted on 13/1/05 at 06:13 PM Reply With Quote
cbr vs GSxr1100
i am possibly going to go for a BEC but not sure
But as funds are tight i thought i would do some homework, so not to make as many mistakes.
which would you say is the better engine for a first timer the CBR or GSXR1100.
i read somewhere that the latter was not a good first engine, but could not find why.
other recomendations also appreciated
oh and is it best to buy the whole bike or an engine 'package' with enough to run it.
thanks
p.s. bike engine will be completly different to the diesels i grew up with so i might just put a tractor engine in it.
Why is it that people say they "slept like a baby" when babies wake up
every two hours?
posted on 13/1/05 at 06:40 PM Reply With Quote
im not familiar with either engine, but do be careful if you buy a bare engine - you can end up spending a lot of money getting together all the bits you need to make it go! been there, done that.... fortunately it was cheap to begin with!
phelpsa
posted on 13/1/05 at 09:16 PM Reply With Quote
Yes, but he's not buying 4 engines
posted on 13/1/05 at 09:36 PM Reply With Quote
[scarface]
'ees a fonny guy, eh...
[/scarface]
if you've never watched it, it is much recommended
i would sell a few but its hard to part with them...
stevebubs
posted on 14/1/05 at 02:12 AM Reply With Quote
Gixxer 1100 is an air cooled beast so need to be careful with cooling etc. (likes plenty of air)
Plentiful now as the sidecar guys moved to other engines last year.
Not that well supported in BEC so will most likely need to source bespoke items such as mounts, prop flange, exhaust etc
blade engine is well trodden and everything available off the shelf
Ideally you need to ensure you get the following from the supplier:
Loom
Carbs etc
Engine
i.e. everything you need to start it up. If you source each separately, you run the risk of them being from a slightly different model and not working together
If you're going BEC then I'd thoroughly recommend going down the "less is best" route with regards to weight.
Just my 2p...
Rorty
posted on 14/1/05 at 04:36 AM Reply With Quote
The GSXR engines are watercooled and have been for years.
Both the engines you're considering are excellent engines, though for my money, I would probably go for the Honda. They're just that little bit better in all respects.
Here's a guide to buying a bike engine "car kit". LINK.
Cheers, Rorty.
farmboy
posted on 14/1/05 at 08:21 AM Reply With Quote
thanks very much for that, still some pondering to do though
every two hours?
phelpsa
posted on 14/1/05 at 06:41 PM Reply With Quote
Loom
Carbs etc
Engine
Just my 2p...
I could give advice on that
