Squadge
| posted on 21/4/18 at 08:10 AM |
A few bec R1 questions,
Hi everyone, I'm building an R1 engined car and have a few questions, the engine is a 5pw.
How does everyone extend the original fuel lines? Is there a kit that you can diy or is it a custom made job?
Does anyone run a remote oil filter set up as I have clearance issues, if so where did you get it from?
Also, does the original clutch set up need modifying? Or can it be used as it is on the bike?
Thanks in advance
ReMan
| posted on 21/4/18 at 09:10 AM |
Bend your own fuel lines from copper pipe front to back, doubt there a kit of any type. Yo may need to get High pressure fuel lines and a swirl pot
made up though
Some use clutch standard, but uprated springs are common, that all
[Edited on 21/4/18 by ReMan]
www.plusnine.co.uk
Squadge
| posted on 22/4/18 at 01:09 PM |
Thanks for the reply.
