westindy
posted on 21/10/02 at 01:29 PM |
Bike Engines 4 an Indy?
Ive got a Vauxhall 1400cc in my Indy at the moment and want to go bike engined - any experience of what will fit and be the cheapest!! . I was
considering a ZX9R or CBR1000 ( diff is 3.62 on 13" wheels) - anybody any idea's!!!
Paul
MK9R
| posted on 21/10/02 at 01:42 PM |
Zx9R and GSXR1100 are cheaper than blades and stick out a bit more power and have smoother gear changes. I got the ZX9R for £515 including the bike
exhaust. Needed to get a rectifyer and couple of sensors. All in cost £615. Try putting an add on findit.co.uk. I had loads of replys from people
saying they had engines from £400 upwards
ChrisGamlin
| posted on 21/10/02 at 02:00 PM |
With a 3.62 diff and 13" wheels, you'll be very revvy and short of top end speed as both the ZX9 and the CBR1000 engine are low geared overall
compared to a 'blade or most other engines. See the wheel size thread for a spreadsheet to work it out, but with your diff and wheels (assuming
185/60) a ZX9 engine'd car will do 10mph less top end compared to a blade, so will be revving that much more. However you can always get hold of a
3.38 diff to help matters for very little money.
ZX9s and CBR1000s do seem to be cheaper than 'blades at the moment, but bear in mind that the CBR is quite a heavy lump compared to the other two,
around 25kgs more than a 'blade if ultra-light weight is your thing.
Chris
[Edited on 21/10/02 by ChrisGamlin]
westindy
| posted on 25/10/02 at 05:53 PM |
what year of ZX9R
Thanks for the responses - Should I be looking for any particular year of manufacture of ZX9R - can I use the tacho and what other bits should I make
sure I get??.
Regards, Paul
Jasper
| posted on 25/10/02 at 08:09 PM |
Get the newest and verified lowest mileage you can from the most reputable source.
Make sure you get all the electrics including rectifier and ECU box. Airbox as well if you want to use/modify it. Exhaust manifold if possible as they
can be modified. If you can get the clocks as well you'll only need a 'yellow box (£60?)' to make the speedo work.
Get the mounting bolts as well if you can, I just had to spend out £15 to get replacements.
I paid £850 (no vat) for a 1999 ZX9RC engine with 8k miles on clock (which I have) for a reputably reputable (!!) source.
