bikecarbfred
| posted on 30/4/22 at 11:08 AM |
Megajolt and knock sensor
"The Phormula KS-4 Knock Monitoring Tool contains all the advanced features of the Phormula KS-3 plus:
0-5v Analogue Data Out
The KS-4 contains a true 0-5v analogue data output. Data output rates are configurable at up to a blistering 100 samples per second and fully
compatible with all Data Logging Software, Engine Dyno’s, Rolling Roads and ECU’s. The 0-5v output can be integrated with an ECU to provide closed
loop knock control.
Phormula Knock Datalogged"
I assume from here that this knock sensor can be trigged up to the 0.5V aux connector on the megajolt lite jnr and monitor knock against RPM graph?
snapper
| posted on 30/4/22 at 09:00 PM |
It’s spelt Phormula…
I’m out
I eat to survive
I drink to forget
