kaymar
| posted on 23/2/05 at 08:04 PM |
general advice pls
i had untill now not considered a bike engine assuming it to be financially beyond my dreams. however i am suprised how some engines can be cheap in
reallity and i am quite taken by the honda [pan european, where do you get adaptors for the gbox to prop from indeed the prop as well. sva/emissions
is there a year of engine manufacture to be consider here. all advice will be gratefully received p/s my chassis is standard to book will this be
to heavy? regards martin
| posted on 23/2/05 at 08:45 PM |
you need a sprocket adapter, basically a prop flange with splines cut into the middle. many manufacturers do them, however im not sure if they are
common to fit the pan euro engine - not very common.
as for props, just do a search on the subject as many people have posted details of local companies.
| posted on 23/2/05 at 08:48 PM |
Pan euro is shaft drive isn't it. It runs inline in the bike as well so the job's half done. They are a bit on the big side though.
Someone has done it already in a ST chassis I read somewhere.
stevebubs
| posted on 23/2/05 at 09:12 PM |
Yep - ST themselves.
