Author: Subject: fuel pump&regulator 4 turbo with carbs
KJK
posted on 27/2/05 at 08:56 PM Reply With Quote
any one know which pump & regulator to use when turboing bike engine with carbs,and also how do you equalise prssure in float bowls.
Wadders
posted on 27/2/05 at 09:08 PM Reply With Quote
This is a good place to start
http://www.turbo-bike.net/
jambojeef
posted on 27/2/05 at 10:11 PM Reply With Quote
Hi there,
Float Bowls - You just connect the breather pipes from your carb float bowls to your inlet manifold - normally 2 in Keihin / Mikuni carbs which emerge from the rail att he top of the carb assembly.
Fuel Pump - You need to supply fuel at a pressure around 2 psi higher than your boost pressure at any given time. For this you can buy a boost sensing pump which will do it for you or make something clever - I suggest the former! Let me know where you get yours from - I'll need one soon!
