Oliver Jetson
| posted on 22/3/05 at 11:12 AM |
R1 Fixing Bolt Identification
Hey up,
Does anyone know what type of bolt needs to be used for the upper mounting of the R1 engine (ie the one that is at the front top when engine is in the
car)?
Oli
Ferrino
| posted on 22/3/05 at 01:36 PM |
If it's the one I'm thinking of then it's M12 x 1.25. Don't quote me on that though
richijenkin
| posted on 22/3/05 at 02:02 PM |
same as the wishbone bolts?
Coose
| posted on 22/3/05 at 02:05 PM |
Nope, the wishbone bolts are M12x1.5mm, whereas the engine bolts are M12x1.25mm. Go to your local Yamaha dealer and buy some genuine items -
they're about £1.80 a piece!
[Edited on 22/3/05 by Coose]
Spin 'er off Well...
Oliver Jetson
| posted on 22/3/05 at 02:35 PM |
Or get them off the shelf from work!
Cheers for the info
Coose
| posted on 22/3/05 at 02:43 PM |
Ah, that would do it! Make sure they're at least 10.9 though, and not stainless....
Tell me to shut up if you knew that already!
Oliver Jetson
| posted on 22/3/05 at 03:10 PM |
Bit rude but you said it - Shut up Coose
Thanks for the help though,
Oli
