tim windmill
| posted on 25/3/05 at 09:13 PM |
Warning indicator
using 929 fuel injected fireblade with standard clocks. When the engine is running the red warning light stays lit and the the Fuel Injection
indicatorl also comes on. The engine runs fine. I think that if it is a fuel injection fault or coolant fault the warning light will flash and other
indicators will come on. i have dry mounted h-vix servo do i need to short anything out or bypass something to remove the fault light.
the only wire i have shorted is the side stand.
Any ideas?????
Cheers Tim
tks
| posted on 26/3/05 at 06:22 PM |
check another simple things..
like:
air valve's?
does it run on all cilinders??
when i was trying to get it workes i blew up a transistor in the MCU from one Bobine, i opent up the mcu and soldered a new one in and now it
works.....
also when the temp sensor isn't conected and stuff like that it will come up.
TKs
tim windmill
| posted on 28/3/05 at 07:49 AM |
problem sorted ,h-vix servo was stuck in one position freed off and warning light gone out.
