Ben Smith
| posted on 29/3/05 at 09:55 PM |
Carbs or injection on R1
Which would be best taking a few things in to account
1, SVA emisions.
2, Tuning later on as a N/A engine.
3, Possibilty of adding supercharger or turbo.
Ben.
ChrisGamlin
| posted on 30/3/05 at 10:02 AM |
Seeing as all R1s are newer than 1995 then I would say injection all the way, on the proviso that you get a Power Commander or similar so you can
adjust the fuelling.
With carbs whenever you need to change the fuelling, you need to re-jet the carbs, with FI, you just change the setting on the Power Commander via a
laptop. You can also control the emissions easier by just leaning it off for SVA etc, you could even have an "SVA map" that you just
switch to when you go for the MOT/SVA!
As to turbo/supercharging, depending on the boost you run you might need additional injectors anyway, but FI should still give you a better base to
start from than carbs.
Chris
smart51
| posted on 30/3/05 at 10:32 AM |
early carbed R1s are half the price of the newest FI ones. Do you need the 170 BHP that much more than the 150?
On the other hand, R1s with a cat can sometimes pass SVA as the are, or so I am told. Most of the rest of them can pass if you fit a bigger cat from
a car. with carbed engines you need a full air bleed system with a cat, again, so I am told.
ChrisGamlin
| posted on 30/3/05 at 12:02 PM |
I was assuming we were talking about the 2002/2003 FI engine which is the same power as the carb engine, and not much dearer to buy. The 2004/5 175bhp
one isnt really proven yet in BECs, and as you say - a fair bit more expensive.
[Edited on 30/3/05 by ChrisGamlin]
