New Topic New Reply
Author: Subject: live axle position
kaymar
posted on 8/4/05 at 10:48 PM Reply With Quote
live axle position
sorry me again
the book says that the rear shox must be square/ vertical to the upper mounting point, if the axle is mounted about an inch or so further back in the chassis would this alter handling or cause other problems, martin
gazza285
posted on 8/4/05 at 10:54 PM Reply With Quote
No.
Mark Allanson
posted on 8/4/05 at 10:59 PM Reply With Quote
No
Mark Allanson
posted on 8/4/05 at 11:01 PM Reply With Quote
"sorry me again"
Don't appologise, I double checked just about everything I did on here to make sure I wasn't about to cock something up
kb58
posted on 9/4/05 at 01:03 AM Reply With Quote
Short answer: No
Longer answer, off by 1" over, say, 12" is an angle of about 4.5 deg. All that means is the shock will move 0.4% less then it would if directly above. You'll never notice.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
kango
posted on 16/4/05 at 05:33 AM Reply With Quote
I had to move my shock about 75mm back from the center of the diff, because my shocks are too long.
What influence will this have? I have standard 180 lb/inch springs.
kb58
posted on 16/4/05 at 05:49 AM Reply With Quote
You'll be fine.
New Topic New Reply
