sting
posted on 16/11/02 at 10:10 AM |
3 & 4 way brake pipe journals
Hi guys on your chassis how have you mounted these. STM told me to rivnut them but where? At present i`m thinking of the front upper cross member and
on the offside diagonal rail near the diff mount.Any ideas
Sting![](/images//smilies/sad.gif)
ChrisGamlin
posted on 16/11/02 at 01:34 PM |
Mine is on the x-member between the two rear lower front suspension pickup points (if that makes sense), and my one for the rear brakes is on the live
axle itself so you only need to run one braided hose to the axle, but I assume yours is an IRS so can't really suggest a suitable location. The
thing is, you don't really need to fix them to the chassis at all, if you put a couple of brake pipe clips either side to hold the pipes, then the
union wont go anywhere, don't take it as gospel that this is OK for SVA tho.
One thing I would say generally is try to keep the whole system lower than the height of the calipers (i.e not along the top rails), so that you dont
get too many high points in the system that can make it harder to bleed. Also mount the brake light switch pointing downward so that it doesnt hold
air in it.
Chris
ChrisGamlin
posted on 16/11/02 at 01:36 PM |
DOuble Post
[Edited on 16/11/02 by ChrisGamlin]
sting
posted on 16/11/02 at 04:21 PM |
Thanks Chris much appreciated![](/images//smilies/wink.gif)
