KJK
| posted on 17/4/05 at 08:30 PM |
chain driven (what size chain&sprokets)
is there an easy way to work out number of teeth on front &rear sprockets needed for a given wheel & tyre size,
sgraber
| posted on 17/4/05 at 10:14 PM |
Just use the chart on this website
http://www.afamusa.com/gear-ratio.html
Ooops - pressed submit too soon.
Once you know the ratio you want, you can use the calculator here http://www.locostbuilders.co.uk/~mk9r/ to determine your speeds according to any
wheel/tire size.
[Edited on 4/17/05 by sgraber]
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
tks
| posted on 17/4/05 at 10:17 PM |
why should you uset that??
what it soow difficult in
saying Engine = 10 Wheel = 50
Soow RPM is going down with factor 50/10 = 5??
i always go to the Cycle example??
if you change to bigger in the back then you have more force but less speed...
soow rpm is diveded.... else it is multiplicated...
TKS
