rayward
| posted on 22/4/05 at 01:40 PM |
1200 bandit engine
Anyone know if these angines have been fitted to locosts??
any pros or cons??
ta
Ray
phelpsa
| posted on 22/4/05 at 02:28 PM |
Im fitting a GSXR1100 engine, which is virtually the same. Cons: overheat quickly, clutch slave cylinder infront of output shaft (can be fixed with a
quick call to Z-Cars). Pros: Lightweight and simple (no radiator/water etc.), torquey (long stroke), cheap, VERY strong and reliable, very tunable.
If you want anymore info then ask
Adam
rayward
| posted on 22/4/05 at 02:52 PM |
thanks for that adam, will you have to mod the sump (baffle. dry sump etc)?
as far as the overheating goes, i thought about a large oil cooler, piped in through a stat, and a couple of big electric fans (one blowing, one
sucking oo err missus) to get a good airflow over the engine especially at standstill.
When you say cheap, how much do you reckon for a decent one?
Ray
phelpsa
| posted on 22/4/05 at 02:56 PM |
I have a mahooooooosive mocal oil cooler, and a 12" fan, which should be enough for hillclimb runs .
I sent my sump off to Z-cars to be baffled, but they sent it back. Apparantly these engines are very sensitive to how much and the temp of the oil.
A decent one might be around £500, but im not completely sure. They will be alot cheaper than the superbike engines though. I seem to remember someone
fitted a bandit 1200 engine in a Striker a while back aswell, so it can be done!!
Adam
Taz Surfleet
| posted on 4/5/05 at 01:41 PM |
Hi chaps
if either of you need a spare engine call me I have a cpl lying around which I will be prepared to let go at a modest sum !
