smart51
posted on 29/4/05 at 11:49 AM |
Tyres
I've just picked up a set of wheels and tyres off eBay, 2 [almost] new tyres and 2 part worn.
Should I put the new tyres on the back of my BEC or the front?
flak monkey
posted on 29/4/05 at 12:02 PM |
Stick the new ones on the back, they ought to grip better than the part worn ones.
The back ones will wear out faster than the fronts. When you have knackered the back ones, get the whole lot changed for Avons or Toyos...
Sera
http://www.motosera.com
posted on 29/4/05 at 12:04 PM |
new tyres on front ----- put it this way a blow out on the front isn't funny -- on the rear it is easier to control.
clbarclay
posted on 29/4/05 at 12:19 PM |
Or get 2 new tyres now. For all you know one or more of the part worn tyres could be damaged from kerbing etc.
jestre
posted on 29/4/05 at 02:25 PM |
I usually replace the drive wheel tires first. then transfer the worn tires to the other two positions.
zilspeed
posted on 29/4/05 at 06:28 PM |
First of all.
What are the make and model of tyres ;-)
John F
Tyre fanatic faction....
MarkL
posted on 1/5/05 at 08:24 PM |
Tyre manufactures reccommend that you put new tyres on the rear, thats a change from a few years ago when it was the opposite way around.
smart51
posted on 2/5/05 at 05:25 PM |
The newish tyres are pirelli P6000, the part worn are continental EcoConti.
I plan to use these tyres during the build, to hold the car up, and for the first few hundred miles whilst I'm getting a feel for the car.
My main concern is not to crash it into a tree before I get the hang of it (or aftwards either). So I want the best grip / handling.
Isn't it true that part worns have more dry grip and new tyres better wet grip?
clbarclay
posted on 2/5/05 at 05:46 PM |
Reworded slightly, with off road tyres they peak when they are slightly worn. However off road tyres have dirt etc. between them.
Road tyres are on a relatively solid flat surface, so there probably ist so much to gain/lose from tyre wear. Untill tyre is illegal of course.
[Edited on 2/5/05 by clbarclay]
