mkblade
| posted on 6/6/05 at 09:39 PM |
fireblade
hi everyone ,i just fitted a new rectifer/regulater to my mk indy ,its the upgraded one with fins ect .all works fine now although it still gets quite
hot ive made a ally bracket for it to sit on .has any one put a fan on theirs as well to help it stay cool ?
many thanks
ChrisGamlin
| posted on 6/6/05 at 09:40 PM |
Yep, my standard one wasnt mounted on anything metallic but I had an old Athlon PC heatsink and fan on for 3 years and it never fried itself.
colibriman
| posted on 6/6/05 at 09:47 PM |
yep...I've got a double pc fan on mine too..
need a bike engine? - www.colibriman.com
SVA ready Mk Indyblade possibly for sale.....if the offers good...!
tks
| posted on 6/6/05 at 09:55 PM |
yess
if you have acces to a Tig welder
proberly the best thing you can do is
with some points welding to an athlon/intel heat sink with fan
Tks
ReMan
| posted on 6/6/05 at 10:08 PM |
Tks
I would think that this may overheat it ?
Or kill its sensitive electronic components, TIG is electric isnt it?
I did this, token gesture, but we`ll see when I run it up.......
www.plusnine.co.uk
mkblade
| posted on 6/6/05 at 10:44 PM |
has anyone got a good pic of there fan setup ,si i could do the same ,also isnt the fan out of a computer 240volt ?
how would i convert it to 12v
many thanks
ReMan
| posted on 6/6/05 at 11:09 PM |
many thanks
I thought that was!
It was only a £2 fan and heatsink, I had already set my location, with better planning you could fit a really big h/s and fan, only about £10 too.
There must be some irony in the fact that people want to water cool their pc's really
No, all the fans are 12V, ready for when people fit them in cars
www.plusnine.co.uk
ChrisGamlin
| posted on 7/6/05 at 01:25 AM |
Something like this should be fine Id think
The "Akasa AK-675 " £6 + delivery from
Overclockers.co.uk (5th one down)
As ReMan says, all PC fans are 12v, the PC power supply converts the 240v AC into 12v DC (and other voltages) for the PC components to run on.
[Edited on 7/6/05 by ChrisGamlin]
chrisf
| posted on 7/6/05 at 03:27 AM |
Here is a pic of mine. I used 1" U section ali and drilled it for extra
holes.
--HTH, Chris
mkblade
| posted on 7/6/05 at 06:01 AM |
ok thanks guys ive got a good idea now i will get one hopefully it will cure the heat problem
thanks
