Northy
posted on 7/6/05 at 03:04 PM |
Brembo disks?
Hi guys,
I have a pair of new Brembo disks with the following on them:
06 97 B AA MIN TH 11.4 MM
Is there any way to work out what car they are for?
Graham
tks
posted on 7/6/05 at 07:29 PM |
well
it are rears...
measure the high and count the holes
and if i was you i will go to brakes international and spend a couple of hours there searching..
or call al brembo shop..etc..
MIN TH = minimum thickness 11.4 mm..
sow the disc wil lmeasure new some 12,5 / 14mm?? at max..
TKs
gys
posted on 8/6/05 at 06:18 AM |
It is much easier: Brembo
Then select 'search by dimensions' or use the Brembo reference.
Man kann ein Auto nicht wie ein menschliches Wesen behandeln – ein Auto braucht Liebe...
Northy
posted on 8/6/05 at 08:57 AM |
Does anyone want some Front disks for a Ford Sierra/Sapphire, 1.3-1.6
Brembo P/N: 08.4946.20
I was sold them as Sierra rears....
Graham
