chrisf
posted on 21/6/05 at 08:06 PM |
Clock loom/pin-out help!
Gents:
My fireblade engine came with a Westfield-modified engine loom. The previous owner used aftermarket gauges and did not keep the clock loom bit: the
plug. I bought my standard Honda gauge cluster but do not have a way to interface with it. Moreover, I cannot find a wiring diagram that has the
pin-outs listed. I enquired about and evidently, one can only get the entire loom, not just the plug.
Any ideas? I rather like the gauges but don’t fancy spending $100-$200 on the engine loom—especially since I already have one.
--Thanks, Chris
jambojeef
posted on 21/6/05 at 09:24 PM |
Hi Chris,
I had the same problem - Ive gone down this route to start with maybe think of something better later.....
Get some network cable or other single core wire which comes in stranded pairs and cut 20 (or however many you need) into about 10cm long sections.
Solder onto the clocks. Solder leads onto any old connector you like and bind the lot up with self amalgamating tape with something like an old
plastic ruler to prevent flex.
Very locost!
Geoff
ReMan
posted on 21/6/05 at 10:27 PM |
I might be able to help with the pin outs,
depends on the age.
Show us a pic of your clocks, they may also have a letter such as B/BGon the body, this ties with the wiring diag.
Also some have screw terminals on the clock bodies which you could use, again depends on age, and also small (5mm?) standard uninsulated crimped
spades fit directly onto the clock sub-loom plugs.
HTH
www.plusnine.co.uk
chrisf
posted on 22/6/05 at 12:55 PM |
OK, here are the pics of the clocks and the pins.
![](/galpreviews/a227998-Clocks2.JPG) ![Rescued attachment Clocks2.JPG](/gallery/a227998-Clocks2.JPG) Rescued attachment Clocks2.JPG
chrisf
posted on 22/6/05 at 12:56 PM |
And again
![](/galpreviews/a227999-Clocks.JPG) ![Rescued attachment Clocks.JPG](/gallery/a227999-Clocks.JPG) Rescued attachment Clocks.JPG
chrisf
And yet again...
![](/galpreviews/a228000-Clocks3.JPG) ![Rescued attachment Clocks3.JPG](/gallery/a228000-Clocks3.JPG) Rescued attachment Clocks3.JPG
chrisf
posted on 24/6/05 at 02:17 PM |
Bump!
So gents, any idea how to determine which pin goes to what? I'd rather not buy the whole loon for a simple plug/wire color.
--Thanks, Chris
ReMan
posted on 25/6/05 at 07:56 AM |
Sorry, can't find this information on the actual pinouts from the clocks by pin. The wiring diagrams show the connections colour coded but you
cant do it without the loom side plug with its wires atached.
Someone on here thats actually used these clocks may be able to help if they can physically match the colour to the pin..........?
As for making the connection though without the genuine plug, it may be difficult as the pins are so small, unless you can solder onto each pin
carefully then encapsulate the whole job with resin or liquid rubber?
Might be a whole lot easier to keep an eye out for a loom at the right price.
Sorry couldnt be more help.
Colin
www.plusnine.co.uk
