Author: Subject: emissions
shed
posted on 26/6/05 at 12:35 PM Reply With Quote
emissions
can someone please help ,,how do you get a r1 carb engine through the emissions test? its ok on first idle but on fast idle the lambda is way to high and there is no way that we can get it down.
any advice is welcome as my sva is tomorrow
ChrisGamlin
posted on 26/6/05 at 01:36 PM Reply With Quote
Ive never had to do an SVA emissions test with a post 95 engine before, so I havent got much first hand knowledge but the others might be able to help a little quicker if you maybe post a bit more detail on your exhaust setup , such as do you have a Cat, have you blocked up the AIS etc?
Chris
OX
posted on 26/6/05 at 02:09 PM Reply With Quote
dude,on thursday we pi55ed the fast idle emmisions ,co was .2 and the hc was 56 and the lambda was 1.010 the problem was getting the low idle co to below.5 ,,so i went weaker on the mixture which took the lambda up to around 1.028 but the low idle was still over .5 ....i said to you we should have a look at the float hight as i was sure the fuel was dribbling up out of the mainjet/needle jet on carb 1 and 4 .Its to l8 now so go for the retest ,get it passed on every thing else and then we can strip the carbs and give them a good going over,,,i dont think the air bleed system will work as the lambda is nearly at its limits allready
OX
posted on 26/6/05 at 11:39 PM Reply With Quote
cant go any richer as the low idle co is over .5 allready
[Edited on 26/6/05 by OX]
