Xy
posted on 5/7/05 at 11:57 AM |
Propshaft movement
Hi all,
I've got a Bailey Morris two-piece propshaft on my Fireblade car and recently I've been getting a vibration through the drivetrain when I
'let off' the throttle or when I am just on part throttle when at motorway crusing speeds (for example).
When I reapply the throttle the vibration goes away.
I've had a look inside the centre tunnel to check that everything is bolted down, and the only thing that I can see is that there is a fair
amount (20mm in all directions) of movement of the centre UJ inside the central support housing...
I know that BECs have quite 'noisy' drivetrains, but the amount of movement of the centre UJ of the propshaft seems a little bit
concerning...
Has anyone got any experiences/advice with regards the movement of the propshaft ?
TIA
Matthew
carnut
posted on 5/7/05 at 12:09 PM |
I believe chatter between the dogs in the gearbox. This only happens under very low loads. As you said it goes away when you accelerate, this is
because you are applying a load to the dogs which is keeping them constantly in contact.
You may also notice if you lift off fully, the chatter disapears. This is because you are loading the other side of the dogs.
I know its annoying but I dont think it does any damage to the gears as there very little force involved in the impacts. My car does this and I know
of several BIG bikes that do it.
I don't think there is anything whrong with your prop.
Hope this helps.
Carnut
[Edited on 5/7/05 by carnut]
carnut
posted on 5/7/05 at 12:12 PM |
Just noticed what you said about the movement in the centre bearing. Sounds like this may be the cause.
tks
posted on 5/7/05 at 12:13 PM |
mhh
it will depend on the amount of play in your centre bearing..
mine is rock solid and i only can move it when using the car...
by hand maybe one mm
its the standard sierra Bearing..
Tkc
Xy
posted on 5/7/05 at 12:40 PM |
Thanks for the swift replies !!!!
The movement of the propshaft on my car is much much more than 1mm... and I can easily move it around 'by hand'...
How is the central UJ supported? Is it just by a rubber 'bush' or is there something more substantial ??
mad-butcher
posted on 5/7/05 at 05:31 PM |
for want of a better word there is a crude bearing on the short part of the prop (just in front of the UJ) this in turn is supported by the rubber
donut which in turn is incased in the metal supporting bracket
tony
ChrisGamlin
posted on 5/7/05 at 07:50 PM |
The earlier transit centre bearing does seem to have a fiar bit of movement in the rubber, I can try in the morning but I wouldnt be suprised if its
around 10-20mm movement on mine too.
As carnut mentions, you do get a clatter at neutral throttle where the gears arent under load, but its not really noticable as a vibration. Also check
your prop flange bolt hasnt come loose and also your diff flange doesnt have any movement in it from a knackered bearing. Ive had both of these happen
to me and they both caused vibration in the driveline, although probably on throttle as well as off.
Alez
posted on 6/7/05 at 02:36 PM |
I agree, I recall quite a lot of movement, maybe about that figure. My setup is a Bailey Morris prop in a Fireblade, too. The prop has been repaired
recently.
BTW my rubber joint had quite a lot of grease applied to it which, I was told by the prop specialist garage, had damaged it (mine was replaced). So
always use a rubber-friendly product to prevent it from getting dry.
Alex
[Edited on 6/7/05 by Alez]
Xy
posted on 6/7/05 at 08:55 PM |
OK, thanks for all the replies so far. So it sounds that the movement of the propshaft is nothing out of the ordinary...
I've owned the car from new, but have never thought about lubricating the central rubber support 'donut' ..
Is this something that I should start doing ?
I've now had a further good look around the propshaft mounting points (front and rear) and nothing seems out of place/loose.
The differential (freelander) was also securely mounted in position.
Should I now turn my attention the gearbox end of things.............
