Author: Subject: 1998 Fireblade carb plumbing
chrisf
posted on 11/7/05 at 02:59 PM Reply With Quote
Gents:
This is a pic of 1998 Fireblade carbs. What are these inlet/outlet tubes and where do they need to go?
ChrisGamlin
posted on 11/7/05 at 07:21 PM Reply With Quote
Chris, both of them are breathers, they usually attach to the airbox so ideally you need to route them so they can breathe away from the carbs somewhere, but I just ran mine like that and they were fine, never breathed anything.
Chris
chrisf
posted on 11/7/05 at 07:55 PM Reply With Quote
Chris:
You let them dangle about or did you put a fancy K&N filter on them? I just realized that there is a breather on the head as well. That too probably needs a filter as wel...
--Thanks, Chris
ChrisGamlin
posted on 12/7/05 at 05:23 AM Reply With Quote
It was probably not the ideal way but I just let them vent to fresh air, although a filter would be good. The big one in the middle, you could just put a boss on the bottom of your air filter plate and route that back into the induction side as on the bike?
Chris
mkblade
posted on 12/7/05 at 09:17 PM Reply With Quote
hi ya yes they do go to the air box im going down the garage tomorrow nite so i will check and get a pic
