MK9R
posted on 27/12/02 at 03:40 PM |
Zx9r running
After sorting out the ignition switch resistor, the engine started up fine, but as soon as i tried to rev it, it cut out. I cleaned the float chambers
out (full of shite!) but still no luck. It would rev if fuel was squirted down the carbs, but as soon as that was burnt off it would cut out. After a
couple of hours scratching around i gave up.
Then i spoke to martin at MK (when i ordered chassis) and found out that if the bikes air box isn't attached it won't run as the vacume butterflys
wont open. So i've ordered the jetting kit and air filter from tts performance (£100).
You may all know this, but i didn't, so i thought i'd put this up here for other numpties like me!
Jasper
| posted on 27/12/02 at 08:09 PM |
Keep em coming - they're all being saved ....
Macca
| posted on 28/12/02 at 11:15 AM |
DITTO!
sting
| posted on 3/1/03 at 04:17 PM |
ditto ditto
P.S. happy new year guys
