Avoneer
| posted on 24/7/05 at 09:26 PM |
Using a Blade Radiator - plumbing???
If I use the diagram from Snoopy's photo archive and the blade radiator as per my pic, what do I need to do with the outlet just below the cap as
there are two there, one just above the other???
Pat...
ChrisGamlin
| posted on 26/7/05 at 04:39 PM |
Hi Pat
The lower, slightly larger one should be a breather back into your expansion tank, the top one will only breath any water if the rad cap lifts under
pressure (ie when on verge of overheating etc), so just leave that one as is, or if you dont want the occasional dribbles, just route it down and let
it breath under the car.
This is how I had it all plumbed in
  pre 98 blade plumbing
Chris
Avoneer
| posted on 26/7/05 at 10:23 PM |
Hi Chris,
Cheers for that - forgot how it all went!
Wait until I start on the loom!
Pat...
ChrisGamlin
| posted on 27/7/05 at 04:33 PM |
Don't worry, I will have changed my name and disappeared by then
