Author: Subject: bec - seized clutch - help
jimmyjonga
posted on 31/7/05 at 05:51 PM Reply With Quote
it appears that the clutch in my zx9r has siezed on. is there a quick way i can fix it??? i was thinking about starting it in gear and jumping on the gas and brakes but i think this may knacker the starter clutch... any ideas????
james
mark chandler
posted on 31/7/05 at 09:33 PM Reply With Quote
Unusual for a wet clutch to jam, dry clutches rust, has it ever worked for You ?
Get someone to tow you with the ignition off in gear, foot on the clutch, if this fails then bump it in gear and try to use the engine to free things. You may find that if you warm the engine fully the heat will assist in freeing the cltch so let it idle for 15 minutes before you start dragging it around at all.
posted on 31/7/05 at 11:13 PM Reply With Quote
Just run it in neutral and rev it a bit to get some oil round, then try starting it in gear with the clutch pressed.
jimmyjonga
posted on 2/8/05 at 08:45 PM Reply With Quote
after leaving the pedal depressed all night - things have sorted themselves out..... lucky..
james
