Author: Subject: r1 carbs
smart51
posted on 3/8/05 at 11:13 AM Reply With Quote
r1 carbs
R1 carbs have a metal pipe going in at one end, going through each carb being linked by smaller and smaller pipes and comeing out of the other end at a much smaller diameter. what is this pipe for?
They have another metal pipe coming out of the bottom. is this the fuel inlet?
Coose
posted on 3/8/05 at 11:17 AM Reply With Quote
Top vent is the slide diaphragm vent, the bottom (between carbs 1 & 2 if I remember correctly) is the fuel inlet.
Go to www.fiche-man.com and he'll send you a cd containing all workshop maunals and parts books as pdf files for a tenner....
Spin 'er off Well...
jimgiblett
posted on 3/8/05 at 11:22 AM Reply With Quote
I think the tube you are refering to is a coolant inlet / outlet to avoid Carb icing. I left mine unconnected.
The fuel inlet is the brass inlet between carbs 2 and 3.
smart51
posted on 3/8/05 at 11:23 AM Reply With Quote
I have a service manual for the R1. It doesn't mention these pipes. The 4 breather hoses I've got sorted, it's these other 3 that are not mentioned that I want to know about.
Coose
posted on 3/8/05 at 11:58 AM Reply With Quote
Just leave 'em all disconnected except for the fuel pipe - it'll be fine!
