kevano
posted on 9/8/05 at 10:15 PM |
charging prob indy blade
new battery fitted but still not charging, tested before but seemed to be fine but been out tonight and it's died again!!
mkblade
| posted on 9/8/05 at 10:26 PM |
hi ya
the rectifer is a common problem to give up mine went last month
kevano
posted on 9/8/05 at 10:36 PM |
indy blade not charging
did yours start misiing then cutting out, how much did you end up paying for one
| posted on 9/8/05 at 10:41 PM |
Common problem - mount on a heat sink and up the front to keep cool. I've heard figures of £30~£40 but not sure if that's good or not.
I believe you can buy heavy duty one's from somewhere... somone will add I'm sure.
kevano
| posted on 9/8/05 at 10:47 PM |
don't really know where it is as i don't know anything about bike engines, any help woul be useful! thanks
shortie
| posted on 10/8/05 at 06:27 AM |
Hi Kevano,
WHat you are looking for is a small metal device about 8cm x 8cm, it has a large white plug going into it with three thick yellow wires and two other
coloured wires.
You can clearly see it in this pic between the header tank and the air filter.
  SVAReady18
They are often located in the engine bay but also often under the dashscuttle and sometimes above the passenger footwell.
HTH,
Rich.
[Edited on 10/8/05 by shortie]
kevano
| posted on 10/8/05 at 08:36 AM |
thats greatl, would it be wise to get one from a breakers or go for brand new.
shortie
| posted on 10/8/05 at 11:50 AM |
I think you can get uprated ones that are much better so I would recommend getting one of them, I think some others have got them so should tell you
where to get one.
Rich.
shortie
| posted on 10/8/05 at 12:03 PM |
Just seen this post.
http://www.locostbuilders.co.uk/viewthread.php?tid=29850
HTH,
Rich.
Andy North
| posted on 10/8/05 at 04:05 PM |
When you say it died again, was this that the engine cut out? or was it just that there was not enough power to start the engine?
andy d (rizla)
| posted on 10/8/05 at 06:44 PM |
i got mine from here,uprated and a finned vertion,they had it in stock,i got next day
http://www.hondaspares.com/newparts/default.asp?mydep=77
kevano
posted on 10/8/05 at 09:49 PM |
blade not charging
it started missing then cut out then bumped it ran for a while then died again! you can drive it round all day and it's fine but drive it for
about 30_40 mins with lights on and it soon starts to miss again and if you stall it or you're too far from home you're buggered!
mkblade
| posted on 10/8/05 at 10:27 PM |
try this Item number: 7991783694 on ebay its the uprated one i have fitted this two mine with a commputer fan to help with keeping it cool
kevano
| posted on 10/8/05 at 10:32 PM |
blade not charging
cheers got one from a crahsed blade coming tomorrow so if all else fails i'll give it a look, did yours have the same symptoms
ASH3
| posted on 10/8/05 at 11:51 PM |
Warning Warning Warning
DONT BUY A BLADE RECTIFIER FROM ANYWHERE THEY ARE A RIP OFF
If youve bought one for more than £20 youve been had n ive been had more than once
Ive found a cure n its cheap very cheap n works brill
I Will reveal all after the weekend i have my reasons!!!
Watch out for this in a new topic to be released soon
| posted on 11/8/05 at 11:26 AM |
Don't tell me. Let me guess................
You're currently in the process of buying every Honda 250 Superdream Reg/Rec in the country. You are then going to set up shop and sell them to
all Fireblade owners with faulty reg/recs and make a nice tidy profit
Can I have my prize now?
ASH3
| posted on 11/8/05 at 06:18 PM |
Well thats pissed on my fire..Hellfire
nearly right not buyin them all just
gettin one for my toolbox bottom draw just in case.
But you gotta admit these boys are makin a killin sellin the nasty little ones for £60 + you can get three superdream ones for that but you only
need one im told there indestructable, mine runs just luke warm not like the red hot nasties of old.They may look like a moped cyl head but sure r
cool
kevano
| posted on 11/8/05 at 09:51 PM |
blade not charging
go on how much you thieving gypsy!!!!
put a new one on today still not showing right voltage!!!!!1
ASH3
| posted on 12/8/05 at 12:03 PM |
Kevano...Ive not recieved my spare one yet
but will willingly let you have it for wat it cost
me under £20 inc postage. But have a bash at this on ebay first
http://cgi.ebay.co.uk/HONDA-250-400-SUPERDREAM-RECTIFIER_W0QQitemZ7992205792QQcategoryZ10460QQrdZ1QQcmdZViewItem
kevano
posted on 12/8/05 at 02:01 PM |
blade not charging
looks like a good cheap alternative! does yours get hot instantly even with no lights on, i can drive it all day fine so it's obviously doing
something but as soon as the lights are on it dies after about 40 mins cheers
ASH3
| posted on 12/8/05 at 04:46 PM |
The old was always hot watever
was on. Yep soon as lights went on
if rectifier is not charging 40 mins is
good..i had two go that way & one over charging
blows light bulbs instant!!These superdream
ones run so cool at all times no need for this heatsink lark that dont work anyway!
ASH3
| posted on 15/8/05 at 11:17 PM |
kevano was that you i see
won superdream rectifier
on ebay £8 WOT a bargain
kevano
| posted on 18/8/05 at 09:27 AM |
mk blade
yeah got the rectifier thanks for the link see if this one works!!!
ASH3
| posted on 19/8/05 at 08:15 PM |
You ok for wireing the
extra wire in? Simply
goes to a dc conection on
loom ( as in a 12v suppy that has been thro the rectifier ) not to batt +
