Author: Subject: fireblade starting..urgent.!!!!!!!!
GeoffB
posted on 14/8/05 at 10:35 AM Reply With Quote
finally got round to starting the engine after a few basic problems it will turn over when you move the sierra switch to number three.(ie start)...but it will not stop when you turn it back to number two..it seems to carry on..!!! this dosent sound normal. but then having no experience of bikes im not sure.
(ps have found the caps lock button and ripped it of..no more shouting)
rayward
posted on 14/8/05 at 10:46 AM Reply With Quote
Sounds like the starter solenoid is sticking, try giving it a tap, had this problem on my bike, was worse when the battery wasn't fully charged.
Ray
rayward
Ray
ReMan
posted on 14/8/05 at 10:55 AM Reply With Quote
Ray
Ditto that, unless you mean its actually running, not just cranking, and won't stop?
Otherwise I suppose if that is'nt it then the ignition switch could be faulty, or you've accidentally wired a latching circuit in,thats keeping the starter relay energised?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
posted on 14/8/05 at 11:23 AM Reply With Quote
I had a faulty switch that you actually had to turn back after it started and had to replace it eventually for the same as your problem.
GeoffB
posted on 14/8/05 at 11:40 AM Reply With Quote
may have cracked it..was told by premier to connect a red and white wire to the relay ( a lucas loom) from the ignition switch..disconnected that and it seems to crank and then stop as it should..
NOW ITS SERIOUS IM OFF TO GET SOME PETROL AND DOUBLE CHECK EVERYTHING
(SHOUTING DELIBERATE BECAUSE I SOOOOOOOO EXCITED..!!)
ChrisGamlin
posted on 14/8/05 at 11:42 AM Reply With Quote
Are you sure you've got it wired in correctly? On the bike, you have a start switch, and a stop switch. This stop switch needs to become connected in order to stop the engine. If you've got your start switch wired into the position 3 on your ignition barrel, but going back to position 2 doesnt make this connection on the stop switch, it wont stop.
posted on 14/8/05 at 01:12 PM Reply With Quote
He's using the Sierra ignition so it's off/on/start. The bike has ign lock/ign lock+sidelights/off/on. The kill switch only cuts power to the coils and leaves all other circuits live. Off cuts all power same on both switches.
ChrisGamlin
posted on 14/8/05 at 01:34 PM Reply With Quote
Ive never used a Sierra ignition switch so maybe I'm misunderstanding, but if Position 1 is wired up to Off, Position 2 is wired to On, and position 3 to activate the start switch, then switching back to position 2 won't do anything because its still in the On position, i.e you'd need to switch right back to Position 1 to cut the engine?
Chris
posted on 14/8/05 at 03:06 PM Reply With Quote
The third position turns the starter over, like pressing the button on a bike starter, position 2 is the running position and 1 is off and steering lock. You have to switch off to get the key out same as your daily drive or bike.
GeoffB
posted on 14/8/05 at 04:51 PM Reply With Quote
nearly there..turns over ok,fuel pump working ok.just not firing up..will try all the usaual suspects.plugs etc.
i now also have a oil leak at the alternator at the bottom where it meets the block.
will get a new seal and try again..tommow.
posted on 14/8/05 at 06:06 PM Reply With Quote
Good luck!
