Author: Subject: R1 clock funny behaviour
smart51
posted on 23/8/05 at 05:04 PM Reply With Quote
the rev counter on my R1 clock flicks between 0 and 8250 RPM when I switch the ignition on. I thought this meant that I had to adjust the throttle position sensor. I losened the sensor and turned it through its whole range with no effect. I remember reading that this adjustment was needed after the TPS was disconnected and so I disconnected it. the rev counter went from 0 to 3000. on reconnection it went back to 8250.
What does this mean?
How do I fix it?
ChrisGamlin
posted on 23/8/05 at 05:35 PM Reply With Quote
Its because the EXUP kaboodle is missing, the proper way of fixing it is to either leave the EXUP servo in the loom or get a box of tricks to fool it, but I believe you can reduce / eliminate it just by joining a couple of the EXUP wires together, although Im not sure which as I didnt need to do it on mine. Im sure Paul R or Jim G will know
Dillinger1977
posted on 23/8/05 at 05:37 PM Reply With Quote
ive heard the r1 clocks rpm blips to show an error if the exup servo motor is missing, but dont know anything more than that..
-Rog
subk2002
posted on 23/8/05 at 05:45 PM Reply With Quote
I had to use a resistor to trick it.
It was for the fuel sender.Might be that.
smart51
posted on 23/8/05 at 08:50 PM Reply With Quote
the EXUP is fitted and does buzz on key off. I guess its the fuel sender then as I don't have one for the bike loom. Any idea what resistance I need?
Coose
posted on 24/8/05 at 08:02 AM Reply With Quote
Yep, it's the fuel sender. I can't remember off hand what resistance is needed, but I'll try to have a look tonight. 10k rings a bell though....
You could put pretty much anything in there if I remember rightly, just so long as it's not either short or open circuit as either of those states will cause the fault code.
Hope this helps....
p.s. Did you sort the clocks back-light problem?
Spin 'er off Well...
smart51
posted on 24/8/05 at 07:30 PM Reply With Quote
Yes, there was no problem all along. You can't see the back lights in daylight, it seems. [embarased grin]. Only after I belled it all out and then took the instrument pack apart did I find that the bulbs were lighting up. Waited until after dark, took a torch, everything OK.
I'll dig out a resistor from somewhere and try it. thanks for the help. again.
Coose
posted on 24/8/05 at 07:55 PM Reply With Quote
Yep, I used a 10k and it works fine....
Glad the back-lights work!
smart51
posted on 25/8/05 at 02:13 PM Reply With Quote
Tried a couple of resistors 33k was too big but 2.2k worked fine. Its funny but in a whole selection of resistors, I had nothing between 2k2 and 33k. Again, many thanks.
