mkblade
posted on 5/9/05 at 06:36 PM |
fireblade carb setting
ive still had problems with fuel on my car ,
ive now stripped the carbs down all jets out diaphrams ect.
what i need to know is what setting have you guys set the mixture screws to ? im on about the ones by the float bowls.
i screwed them all the way in before then backed them off 3 turns is this right??
i also need a fuel pump anyone now of one going cheap mine dosent seem to shutt off it clicks all the time
thanks for help once again
chrisf
posted on 5/9/05 at 11:05 PM |
What problems are you having? I too fiddled with one of the mixture screws. I get huge amounts of fuel pouring out of the carb breather.
I thought it was the fuel pump but it happens even when it's gravity fed...So I now think it is a problem with the mixture screw.
Are you getting the same issue?
--Chris
mkblade
posted on 5/9/05 at 11:11 PM |
my problem is that it is running rich ,its fowling new spark plugs in 4 miles ie 15 mins of running backfiring missing .
i orginanly had the same broble as you the pump was to powerfull and chucking fuel out of the breather,i have fitted a blade pump now but i think it
may be faulty.
have you checked your floats in the bottom of the carms sounds like there sticking causing it to flood and pour out of the breather.
chrisf
posted on 5/9/05 at 11:53 PM |
yeah, I disassembled everything and sprayed the indivivual bits clean with carb cleaner. When I felt the floats, they seemed to move in and out OK. Do
you think this has anything to do with the mixture screw?
I'm certain at this point that the fuel pump is not the probel. I say this because it happens even when I funnel the fuel into the carbs. Any
suggestions?
mkblade
posted on 6/9/05 at 10:07 PM |
i spoke to mac1 today they suggested that i take the floats out by knocking out the small retaining pin in each carb.then you can check those needle
valves they have a black tip to them make sure its clean and spray some carb cleaner down the holes.
as for the mixture screws ive been told different settings between 2-5 screws out each set of carbs are different i guess.
i will be having another go over the weekend
simon
Lightning
posted on 9/9/05 at 09:52 PM |
Mixture screws are only for idle jets. Main jet size would agjust the overall mixture. Usually with through exhaust it needs to be richer. Are you
sure its running rich?
mkblade
posted on 9/9/05 at 10:02 PM |
when adjusting the mixture screws i wind them all the way in then back them off 3 turns, if i back them off more am i richening the mixture or is it
making it weaker ??
