jonboy
| posted on 16/1/03 at 10:58 PM |
speedo calibration
Can anybody tell me how you go about calibrating a fireblade speedo (electronic engine driven type),to run accurately with sierra diff?
Wadders
| posted on 16/1/03 at 11:22 PM |
Hi
the only method iv'e come across to succesfully use the bike speedo in a car is to buy a yellowbox,which is a small electronic gizmo that sits
between the speedo sender and clocks, you can tweak the yellowbox to achieve the correct reading on the speedo. my cars not on the road yet,so i cant
comment how good they are, but loads of bec's use them.
These people are the makers/suppliers
www.blackrobotics.com
Hope this helps
Al
ChrisGamlin
| posted on 17/1/03 at 12:01 AM |
Mine has a Yellobox and it works fine, you need about 60% adjustment which initially seems out of range of the normal unit, but you switch it to
mph/kph conversion first to reduce it by 1/1.6, then fine tune it from there.
Chris
jonboy
| posted on 17/1/03 at 08:21 PM |
speedo calibration
Cheers chaps, thats exactly what i needed to know
