pathfinder
posted on 20/9/05 at 08:00 PM |
Bec Prop shafts
How have people modified their Sierra prop shaft for use in bike engined cars? I know that you can buy purpose built props but im after the low cost
option. Photos would be a great help!
pathfinder
posted on 20/9/05 at 08:35 PM |
think this is what i need but its not standard Sierra is it? or is it?
  Rescued attachment prop
Guinness
| posted on 20/9/05 at 09:25 PM |
I got my donor prop modified by MK, they basically cut the front splined bit off and weld another UJ and sliding joint onto the front. This UJ then
bolts up to an adaptor that sits on the bike gearbox output. As an alternative I know MNR do a completely new unit for about £280.
I know its tempting to go locost with a prop shaft, but think of the consequences of a failure. A steel tube spinning at a 1000 rpm or more, flailing
about inside a transmission tunnel thats about 3" from your or your passengers thigh. If in doubt have a search for Woodsters comments in
"why did this happen" and Billy's "prop failed at high speed".
Sorry, but if you can find someone who has the skill to cut, modify, weld and balance a prop then use them, otherwise don't risk it. IMHO.
Mike
mkblade
| posted on 20/9/05 at 09:59 PM |
mk did mine a while back now modifed sierra
Avoneer
| posted on 20/9/05 at 10:21 PM |
Try Dunning and Fairbank, Leeds
I got mine made to order for £160.
That's brand new, with a centre bearing, torque resiliant tube and sliding rear section and guarantee.
Pat...
| posted on 21/9/05 at 12:36 AM |
Pat...
BL00DY 'ELL that's a good price
Coose
| posted on 21/9/05 at 08:06 AM |
Mine was a fair bit more than that from D&F, but I had my torque tube fitted at a later date.... I would highly recommend them though!!!
Spin 'er off Well...
Winston Todge
| posted on 21/9/05 at 02:15 PM |
The torque resilient tube is basically a tube connected to the engine running inside another tube connected to the diff with rubber effectively
connecting the two tubes together?
Is this correct and what are the main advantages over a solid prop?
Less vibration and backlash when lifting off at low revs?
And Coose is there a large difference between a solid and a TRT prop?
Thanks for any help,
Chris.
