Author: Subject: BEC
gary gsx
posted on 25/9/05 at 05:26 PM Reply With Quote
BEC
Ok just looking about ebay for bike engines fireblades not to bad a price, But has any one tried a v twin lots of VFR 800 cheaper + Aprilla 1000 lumps
smart51
posted on 25/9/05 at 06:36 PM Reply With Quote
I looked at an aprillia RSV Mille engine briefly. I think it would be good. I went for an R1 for simplicity. I reckon that the cost saving for an unusual engine would be more than lost in getting a cradle and exhaust. There were also plenty of people here who could help when my R1 didn't start. Aprillia knowledge maybe a bit more thin on the ground.
That said, The Mille is torquey and has good gear ratios for a BEC. It is also dry sumped.
locoboy
posted on 25/9/05 at 07:36 PM Reply With Quote
One guy on here - Spunky used a VTR Firestorm V twin if i remeber correctly, might be work contacting him if you have any specific questions.
Locoboy
Lotusmark2
posted on 25/9/05 at 08:23 PM Reply With Quote
I am using a VTR in my single seater but I think there may be an issue fitting a drive shaft adaptor on the drive spindle (I am running chain drive)
Gav
posted on 25/9/05 at 09:58 PM Reply With Quote
also wouldnt the angle the engine needs to be on mean that one of the barrels would be sticking out th side of the chassis? or would the 60degree V be close enough for this not to be a problem?
posted on 25/9/05 at 11:37 PM Reply With Quote
You most likely would very much need a TRT prop to stop it shaking to bits on acceleration!
gary gsx
posted on 26/9/05 at 06:04 AM Reply With Quote
Cheers Chaps ill go with the blade lump as you say plenty of people have used so lots of knowledge about and parts.
Cheers of to build chassis Gary
