zzrpowerd-locost
posted on 28/10/05 at 10:58 PM |
Mods to book trans tunnel
After reading about mnr suppling bec chassis with narrow trans tunnel if requested got me thinking!
With bike engine there is no need for wide tunnel entrance. How much if any "room" do you need at the front of the tunnel for the
prop?
Can i get away with straight tunnel on drivers side and slight widening on passenger side?
Hope this makes sense!! Well it is late
Avoneer
posted on 28/10/05 at 11:07 PM |
No - The drives side still needs to be the same at the end due to how far over the prop adapter will be on bike engines.
You can make the passenger side straight though, and even bring the engine further back and reduce the length of the passenger side cockpit by upto
12" - I wish I had done this.
The rest of the tunnel between the people can be a lot narrower as well and dead straight.
Hope that helps,
Pat...
zzrpowerd-locost
posted on 29/10/05 at 07:25 AM |
DOH! was hoping to get more room round the pedals!
Could always go LHD
Bob C
posted on 29/10/05 at 06:23 PM |
I put my back prop in through the tranny tunnel top. With a sierra flange it JUST fits (ie you have to wrestle with it a bit to get it in) I
don't know what you'd do with a narrower tunnel. Ah wait a mo - I've used 25mm tube there to beef it up for IRS - still a point to
consider though.
cheers
Bob
