Danozeman
posted on 18/11/05 at 03:10 PM |
Any one changed a toilet?
well as above? Has anyone changed one? are they easy?
Dan
scotty g
posted on 18/11/05 at 03:11 PM |
Absolute doddle mate, if you can build a car this is a walk in the park.
need4speed
posted on 18/11/05 at 03:20 PM |
Agree even done the complete bathroom but haven't built a car yet.
donut
posted on 18/11/05 at 03:22 PM |
Some people say my car IS a toilet!
skydivepaul
posted on 18/11/05 at 03:50 PM |
Piece of piss!!!
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
posted on 18/11/05 at 04:02 PM |
Changed the bog and refitted my bathroom whilst building the car took me a couple of days to replumb, cross-bond and check. Installed electric shower
twin extraction fans (one triggered from proximity sensor) and ceiling lights in halogen.
Still not finished the decoration of it though
jestre
posted on 18/11/05 at 04:06 PM |
2 bolts, 2 nuts, and a wax ring is all it takes.
-=too much horsepower is just enough=-
Scotty
posted on 18/11/05 at 04:08 PM |
nuts and bolts i can inderstand
but a waxed ring !!!!!!
![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif) ![](/images//smilies/shocked.gif)
PLEASE NOTE! All comments made by this person are to be considered "Tongue in Cheek" and are not meant to be taken seriously in any way - so there!
jonbeedle
posted on 18/11/05 at 04:46 PM |
Easy peasy. I fit bathrooms as a sideline!
Turn off water supply to cistern, flush toilet to remove as much water as possible, disconnect overflow pipe and water feed, remove cistern, if
it's close coupled, it will be held on to the bowl by a couple of wing nuts and also screwed to the wall. Keep it upright so as not to spill any
water that's left in it and empty it, I chuck it down the bath plug hole.
The bog bowl is normally screwed to the floor. When unscrewed it should just pull away from the soil pipe. Keep it level because there'll be
some water in the 'U' bend.
It's a good idea to clean and bleach the bog before you start in case you spill any water when taking it out.
If you need any help give me a call, 01842 860668 or 07916351303.
Good luck.
Jon
"Everyone is entitled to an opinion however stupid!"
posted on 18/11/05 at 06:51 PM |
not always as simple as it looks though, some old houses have lead soil pipes, which arent a straight fit with modern fittings. You would need an
adapter i think.
RoadkillUK
posted on 18/11/05 at 07:12 PM |
I replaced the Loo, sink and fitted a bath. Removed a wall, build one, plastered the other 3, fitted the ceiling, fitted spotlights, replaced the
whole of the waste pipe from the roof to the ground (suprised how clean it was and how heavy it was).
Basically, if I can do it, you can
Reminds me, I'll have to sort out the bathroom floor
I know this may seem like I'm blowing my own trumpet but I'm proud of my bathroom, not bad for a first effort
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
posted on 18/11/05 at 08:12 PM |
The hardest part when I did mine was removing the screws holding the pan to the floor . Mind you its a crap job.
steve_gus
posted on 18/11/05 at 08:38 PM |
did all three of mine. The downstairs one was the biggest hassle as it wasnt screwed but CEMENTED to the floor!
the biggest hassle was getting the close coupled cistern not to leak water.
try and get the new loo ready to swap over as soon as you take the old one off, and put water in it - will stop manky stench coming up!
atb
steve
http://www.locostbuilder.co.uk
Just knock off the 's'!
posted on 18/11/05 at 08:41 PM |
i installed a new toilet a year ago for a tenant, and the flusher flaps broke last month! In future id consider putting solider ones in, the thin
plastic flaps are well shite
steve_gus
posted on 18/11/05 at 08:48 PM |
yeah - in one of mine it was a really flimsy bit of sheet plastic that was like the stuff you get easter eggs in!
I also cant believe how poor quality float valves are nowadays.... the plastic pivot looks like its waiting to fall out!
atb
steve
Danozeman
posted on 18/11/05 at 10:23 PM |
Thanks chaps. Just waiting for the wife to decide what bog and sink she wants. It looks fairly easy.
Dan
Danozeman
posted on 19/11/05 at 09:23 AM |
Another quick question. Are the mountings for the cistern to the pan on close coupled the same? Ie can i fit a different cistern to a pan?
Dan
Ferg
posted on 19/11/05 at 12:52 PM |
Almost always, but not 100%. The bolts generally slide on UK manufactured cisterns, but tend to go through holes in the base of the cistern if from
Turkey, Greece, Belgium etc
You get what you pay for. Beware form over function by the way, just 'cos it costs a lot doesn't mean it's any good. And even if it
looks good it may well be twisted, porous or suffer from oval outlet which will make you swear when the pan connector doesn't seal.
steve_gus
posted on 19/11/05 at 12:55 PM |
the two i fitted looked slightly different, but perhaps I was unlucky!. The way the cistern is bolted on was crap in both cases. Long bolts go thro
base of cistern to bowl, are underwater, and have crappy washers that stop the water falling out.
Make sure that you fit and locate the sealing ring (usually a foam donut) over the spigot that goes into the pan. If you dont fit it properly or omit
it (yep, i did first time as it wasnt in the kit) when you fflush, the pressure blasts most of the flush water out of the cistern to pan joint!
atb
steve
posted on 20/11/05 at 03:24 PM |
Yep, mine stopped working earlier this year and the crappy plastic flap had ripped. In true locost style I made a replacement out of a bit of heavy
duty pond liner, which was much tougher and will probably outlast our current bathroom suite.
