mike smith1
posted on 22/11/05 at 01:28 PM |
Fireblade Sump - Ground Clearance
Calling all fireblade powered BEC,
Can you tell me what ground clearance you have with a standard sump
I have around 30-40mm does this sound about right, my chassis and cradle is a MK, i just expected a little more clearance.
Cheers Mike
ChrisGamlin
posted on 22/11/05 at 01:37 PM |
You really want the sump a maximum of around 1-1.5" below the chassis line (assuming normal 4-5" rideheight), otherwise you're
asking for trouble at the first sign of a speed hump.
mike smith1
posted on 22/11/05 at 01:44 PM |
Thanks Chris, will measure it accurately later, its just a guess of 30mm at the min
Mike
Coose
posted on 22/11/05 at 03:24 PM |
I mounted my r1 in my Striker so that the sump was just above the bottom of the lower chassis rail. Yes, the filter may poke out of the bonnet, but it
paid off when I beached the car in May.....
Be warned!!!!
Spin 'er off Well...
Gav
posted on 22/11/05 at 05:00 PM |
Umm, im making my own cradle atm, whats the height of a MK chassis? its just that ive sat my(book) chassis on blocks so its raised about 35mm from the
floor then place the engine on the floor, and the bottom lugs a the front of the engine which your cradle bolts to, still seems quite a bit lower than
mine, in fact almost level with the bottom of the top chassis rails so if this is correct id what id have to do is notch the cradle rail (25x25 box
section) to accept some 19mm tube to which im gonna weld 2 nuts either end to pass a bolt trough which is gonna hold the engine in position. its just
everyone elses ive seen these are lower than the top chassis rails.
[Edited on 22/11/05 by Gav]
andrew.carwithen
posted on 22/11/05 at 05:36 PM |
I mounted mine so that the sump gasket was in line with the bottom of the lower chassis rail ( so bottom of sump sits about 1 1/2" below it.)
This gives me about 5 to 6" ground clearance (without me sat in it!.)
Andy.
ChrisGamlin
posted on 22/11/05 at 07:25 PM |
Are you sure the car rideheight is going to be that high when you've set the car up Andy? My car seems about average and only runs about
4.5-5" ground clearance from the bottom of the chassis rail. If I recall correctly, the standard blade sump is around 68mm deep, or about 58mm
with a side drain plug. Even my fully chopped one was still 50mm (2" ) deep, the same as the ST billet ones so working on that you're
going to have the sump hanging at least 2-2.5" below the chassis.
Chris
[Edited on 22/11/05 by ChrisGamlin]
andrew.carwithen
posted on 23/11/05 at 04:26 PM |
Chris
Just been out to garage and checked it again.
You're right, Chris. I've actually got just over 4" ground clearance to bottom of sump support fins (I have a side mounted sump
plug) or a good
4.5 " to bottom of sump itself. (car must've 'settled' somewhat after fitting engine.)
It'll no doubt end up less again once I set up suspension etc.
Apparently, according to Pat (Avoneer), Tiger supply too long a front shock for the Avon, which is why my front 'bones are not parallel to the
ground (thus 'jacking up' the front of the car!)
Andy.
