Howlor
posted on 28/11/05 at 08:27 AM |
Quaife reverse box dimensions / weight
Does anyone know the dimensions of the Quaife reverse box. I am actually after the height of the flange centres above the mounting base and the
distance between the two flanges. Also just out of interest does anyone know the weight of these?
Dillinger1977
posted on 28/11/05 at 08:38 AM |
im going to take a randomish stab at 5-10kg?
cant be sure as mine is fitted but its fairly heavy to lift for such a small thing!
ps my reverse box has actually been fitted to your chassis as far as i recall, if its a case of wondering if the propshafts fit.
i'll try and get some dimensions tonight.
-Rog
ChrisGamlin
posted on 28/11/05 at 08:58 AM |
The figure usually mentioned is ~10kgs, not sure how accurate that is though or how it varies with different designs.
Howlor
posted on 28/11/05 at 09:51 AM |
Graham told me that he had drilled the chassis etc using your box so it should be a perfect fit. I am currently looking at all options and therefore
needed the above sizes. At 10kg it is fairly heavy.
Tralfaz
posted on 28/11/05 at 11:09 AM |
Measured Drawing
http://www.quaifeamerica.com/downloads/ga/ga_35G1.pdf
Howlor
posted on 28/11/05 at 12:31 PM |
Thanks. I have downloaded the drawing and it gives me everything I need.
