kurt
posted on 29/11/05 at 08:15 PM |
R1 won't start, tonights update
I've put some more pleas for help on previous thread but nobody has taken the plunge yet. Come on guys, please don't leave me now, it
still won't go!
rayward
posted on 29/11/05 at 08:33 PM |
posted this on the other thread aswell but,
is it carb'd or injection R1?.
is your fuel fresh, as it does "go off" if left for a while.
Ray
froggy
posted on 29/11/05 at 09:15 PM |
probably been said before if all the ingredients are there ,fuel,spark, have you towed it yet sometimes it just wont turn fast enough on the starter
to catch![](/images//smilies/smile.gif)
shortie
posted on 29/11/05 at 09:19 PM |
Silly question maybe but you're not using a Fuel Injection fuel pump and not a carbed one are you, if you use a fuel injection fuel pump it will
pump far too much pressure.
Can you test the flow rate as stated below, this is for a blade but flow rate should be about the same.
Here’s the test in case you want to try it :-
1. Get a suitable measuring jug, normal small kitchen jug will do.
2. Disconnect the fuel pipe by the carbs (make sure you have some rag\kitchen roll under the pipe to catch any fuel that leaks out.
3. Put the end of the fuel pipe into the measuring jug and turn the ignition on so that the fuel pumps for 15 seconds.
4. Turn the ignition off and measure how much fuel was pumped through.
5. The pump needs to pump at least 900cc per minute so in 15 seconds you should have at least 225cc in the measuring jug.
Can you then just confirm how much fuel you get through.
Rich.
kurt
posted on 29/11/05 at 09:29 PM |
As far as I know it's the carburettor fuel pump but I'll measure the flow rate when I drain off the old fuel.
ChrisGamlin
posted on 29/11/05 at 10:10 PM |
Just a suggestion, might it be worth keeping this all in one thread so people dont go over the same things again and to make it easier for everyone to
follow, this is the third thread on the same problems so makes it hard to follow what you have / havent tried and what your setup is
kurt
posted on 29/11/05 at 10:15 PM |
Fair point, I'll keep things on the main thread.
