Author: Subject: Homebuilt ARC welder
jestre
posted on 15/12/05 at 11:04 PM Reply With Quote
Did a search and did not find this posted before so, here is how to build an ARC welder
http://www.dansworkshop.com/Homebuilt%20arc%20welder.shtml
-=too much horsepower is just enough=-
posted on 16/12/05 at 10:19 AM Reply With Quote
It is interesting to note that he used his dad as the guinea pig
land rover field repairs to weld is one or two batteries connected in series, a set of jump leads connected to the battery, the negative to the metal and the postive lead holding the welding rod. Can't be any simpler than that?
