zxrlocost
| posted on 16/12/05 at 11:35 AM |
r1 speedo sensor
Im not at home at the moment but Ive got a funny feeling I may or may not have the speedo sensor for my r1 engine
what does it look like where is it etc
ta chris
Ferrino
| posted on 16/12/05 at 12:02 PM |
quote: Ive got a funny feeling I may or may not have the speedo sensor
Flippin' 'eck - you'd better play the lottery this
weekend with a hunch like that
zxrlocost
| posted on 16/12/05 at 12:08 PM |
meaning Ive most likely got it but couldnt be certain as I did take everything I could think of at the time
Ive got last weeks numbers if there any good to you
ChrisGamlin
| posted on 16/12/05 at 12:18 PM |
Not sure about earlier engines, but my 2003 engine has it bolted into the side of the block under the gearbox mounts. If you look at this pic, where
the gearbox side mounts to the chassis, if you look inbetween the mounts its just under there
  R1 Engine Cradle
About...............................................................................here ^
zxrlocost
| posted on 16/12/05 at 12:21 PM |
ta i can just about see it
Coose
| posted on 16/12/05 at 02:17 PM |
My 2000 is the same if that helps!?
Spin 'er off Well...
