Author: Subject: Mounting blade pump
Avoneer
posted on 26/12/05 at 11:14 PM Reply With Quote
Mounting blade pump
Any easy ways of mounting the pump?
posted on 26/12/05 at 11:25 PM Reply With Quote
The pump normally comes with rubber rings with slots in - a bit of bent ally rivetted to somewhere and slotted into the rubber mount suffices. If you don't have the original mountings Pat I suggest you mount it in a similar fashion using rubber to help cushion the pump.
Triton
Make a clamp like those used for coils on real cars....
www.tritonraceseats.com
www.hairyhedgehog.com
Avoneer
posted on 26/12/05 at 11:32 PM Reply With Quote
Mark - are you stalking me and my posts
Hellfire, didn't come with any rubber.
How about a big "p" type clip made from ali with a layer of foam on the inside and then boltde to the chassis?
Pat...
posted on 26/12/05 at 11:39 PM Reply With Quote
Big P with rubber/foam sounds good
Triton
posted on 26/12/05 at 11:40 PM Reply With Quote
Exactly what i meant..giant p clip.
Yeah, thought you knew ....."Beanstalker"....
Avoneer
posted on 28/12/05 at 03:22 PM Reply With Quote
Solution found.
Exhaust bracket - perfect!
Can mount through any ali panel now.
ChrisGamlin
posted on 28/12/05 at 03:42 PM Reply With Quote
Hi Pat
I would maybe put a bit of rubber in there somewhere to avoid any excessive noise / vibration, but apart from that it looks spot on.
Congrats on the new arrival by the way
Avoneer
posted on 28/12/05 at 03:52 PM Reply With Quote
Cheers Chris.
Was gonna rubber it as well.
Will be mounted on an ali panel that is only sikad (with a thick bead) in place (not rivetted) so that should add further vibration dampening.
Pat...
