Author: Subject: Castrol R4 Superbike
jambojeef
posted on 30/1/06 at 02:08 PM Reply With Quote
After taking my car out for its FIRST DRIVE!!!!! on saturday night, I managed (in time honoured tradition) to break it!
I thought I was gently rolling over a tiny rasied kerb but actually the kerb in question leapt up and bashed a hole in my sump.
Oil all over road - bits of aluminium at the bottom of the street......er oh!
So anyway - I ve got to pick an oil to fill it with now!
How about Castrol R4 Superbike?
The CBR 1000 is pretty much the only bike in the whole Castrol database which doesnt spec R4 as its recommended oil but all the CBR600RR and blades and stuff run it so why cant I?
Any thoughts - what are you running?
Geoff
smart51
posted on 30/1/06 at 02:37 PM Reply With Quote
You've got to use a bike oil if you have a bike engine otherwise the aditives can cause clutch slip on the bike's wet clutch. I just used ordinary castrol bike oil from a nearby halfords. I suppose some people will say that a particular brand or type is superior.
OX
posted on 30/1/06 at 04:32 PM Reply With Quote
any of the named oils will be fine .
morris's oil never creamed up as fast as any of the other oils that we used,,not that that happened much,just on the daily user's that didnt do the miles and get the engine warm .
G.Man
posted on 30/1/06 at 06:08 PM Reply With Quote
Castrol R4 superbike was all I ever used in my bike... great oil
Opinions are like backsides..
gary gsx
posted on 30/1/06 at 06:49 PM Reply With Quote
I use it in my bike too, never had problems with clutch or gear selection
Guinness
posted on 30/1/06 at 07:24 PM Reply With Quote
I used Castol GPS and can highly recommend it, cause it's a lovely red colour and looks dead good all over the side of the road.
Much better than that black stuff you had in yours
Mike
Triton
posted on 30/1/06 at 08:47 PM Reply With Quote
Might have missed the point here but i used to run one of my strokers on Castrol R.....ooooo the smell is too die for but every other weekend i was freeing off the rings.....then at daft speeds it locked up the crank bearings....dry a s bone they were.....ummmm Castrol R no good for a road bike then
www.tritonraceseats.com
www.hairyhedgehog.com
ChrisGamlin
posted on 30/1/06 at 09:07 PM Reply With Quote
Wasnt Castrol R a 2 stroke mixing oil, I didnt think it was meant as a pure engine oil to sit in the sump.
As for putting Castrol R4 all over the tarmac, here's my effort at Anglesey a few years ago, note how good my line was round School corner even whilst the sump plug was escaping and with oil on the rear tyres
My Oil Slick at Anglesey when Mr Sump-Plug escaped :(
[Edited on 30/1/06 by ChrisGamlin]
jambojeef
posted on 31/1/06 at 09:09 AM Reply With Quote
Cheers fellas!
I filled her full of R4 last night - the stuff smells really quite nice! Sort of honey-sweet!
Well heres to it staying in the sump a bit longer than 5 minutes this time....
Geoff
Guinness
posted on 31/1/06 at 09:36 PM Reply With Quote
Hang on Geoff, you can't tell me you bust your sump on Saturday at 5pm and by Tuesday night, you've chopped it and put it back on.
You did fix it didn't you, or did you think it was taking a lot of oil to fill it up
Mike
G.Man
posted on 3/2/06 at 11:09 AM Reply With Quote
Castrol R40 is a 40 grade castor oil designed for dry sump lubication, pre-mix or autolube.. It was originally used on high stressed race 4 stroke engines, but I wouldnt use it in a modern bike engine, it gums up too much...
Synthetic all the way
BTW line into the corner looks a little tight to me, but I havent raced at that track so probably wrong
ChrisGamlin
posted on 3/2/06 at 12:18 PM Reply With Quote
Its actually the second apex of School towards Abbots on this diagram, its a 90-100mph corner and you can't go out too far after the first apex otherwise you never get back on line for the second apex and on to Abbots.
Its the same circuit that 5th Gear use BTW, so you can probably check my lines againt Tiffs to see how badly he does it
[Edited on 3/2/06 by ChrisGamlin]
posted on 3/2/06 at 12:46 PM Reply With Quote
Looks like G.Mans wrong then.......
G.Man
posted on 3/2/06 at 06:23 PM Reply With Quote
Yeah thought it might be a second apex...
so yes I am wrong, it must be like coram? at sneterton
ChrisGamlin
posted on 3/2/06 at 08:23 PM Reply With Quote
Never driven Snetterton apart from in TOCA2 but yep it is a similar kind of corner, although on the approach the horizon is the Irish sea about 200 yards in front of you which is a little disconcerting when turning in at ~100mph!
Here's a video of a Lap at Anglesey (not me), School is the first corner in the vid.
Chris
