Toady1
posted on 10/3/06 at 08:21 PM |
difference in performance
Whats the difference in all round performance between the fireblade and hayabusa engine? obviously i know theres an extra 400cc's and 50 odd bhp
etc, but has anyone had both or been in both that can give me an idea?
cheers!
Liam
smart51
| posted on 10/3/06 at 08:28 PM |
I've not been in either either but I can give an educated guess. The busa will have a lot more torque and so will accelerate harder in each
gear. The blade may (I don't know) rev a bit higher so that you can hold on to each gear a bit longer. The busa has 40% more power one way or
another and so it is going to be noticably quicker. Oh, and as the top speed might be higer as well, the speed at which acceleration starts to wain
will be higher.
Lightning
| posted on 10/3/06 at 09:06 PM |
No intelligent data to offer, but on the last track day the busa powered Westfield shot past my Blade
skydivepaul
| posted on 10/3/06 at 11:04 PM |
depends whose driving. last track day i passed a busa engined westy in my MK Indy R1.
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
DIY Si
| posted on 10/3/06 at 11:29 PM |
Why do you need to know? Neither's slow! Are you upgrading or looking from a fresh build view? And as already said, it will depend who's
driving. Straight line the 'busas should dissapear off into the distance, but rounds the twisties the man/women with the bigger balls will
dissapear. Given everything else is the same of course.
kb58
| posted on 10/3/06 at 11:54 PM |
It's all hp/weight, torque is meaningless. HP ratings take torque into account.
That said, it's likely the only difference between the two will be "Holy Cow!" versus "Oh crap!" Do you care which you
have?
[Edited on 3/10/06 by kb58]
And its book -
http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
OX
| posted on 11/3/06 at 01:08 AM |
they are all good fun but the blade feels rather flat ,i have been in both,the blade is ok up to 100 mph but then it starts to struggle
stevebubs
| posted on 11/3/06 at 01:14 AM |
Not a turbo, was it?
OX
| posted on 11/3/06 at 01:17 AM |
he must of been on his cooling down lap
Toady1
| posted on 11/3/06 at 10:11 AM |
reason for asking is that im looking at buying a blade engined car, and may buy a busa engine to put in at a later date. Obviously i know that the
weights being relatively similar there is going to be a difference, just wanted to know how much of one really. Im a mechanical engineer so can
clearly imagine the obvious effects, am just doing some research into the differences before i go ahead with my choices. cheers for any help.
[Edited on 11/3/06 by Toady1]
Ferrino
| posted on 11/3/06 at 10:22 AM |
quote: the weights being relatively similar
Err, the Busa pays quite a significant weight penalty over the 1-litre engines - something in the
region of 20kg IIRC. That would eat into some of the BHP difference.
| posted on 11/3/06 at 10:39 AM |
Can't speak about Busa, but our mildly modified ZX12R which is allegedly better suited to 7's than a similarly modified Busa is
comparable.
The engine is smoother to drive as it has little or no power band as the blade does. (We have had a blade engine too - no longer tho'
I'd agree with Ox that the performance difference isn't 'miles' apart as you would expect but there IS a difference. You know
you have more torque as the larger engine can continue to pull from higher speeds.
Make no mistake tho' the blade engine is VERY fun
OX
| posted on 11/3/06 at 04:47 PM |
[Edited on 11/3/06 by OX]
JoaoCaldeira
| posted on 11/3/06 at 10:52 PM |
Beyonf the engine weight you have to think in the wet sump (cost and weight) for the 'Busa
Joao
OX
| posted on 12/3/06 at 12:22 AM |
my car is probably 40 or more kgs heavy than my brothers r1 and i am 24 kgs heavier than my brother but it still pulls away from him but the overall
drivability makes it worth the extra money,to me . if i built another one it wouldnt have a dry sump and i wouldnt need a spare set of wheels so i
could get the price down to 8000 ,it would still be heavier but at only £1500 more .the grin factor aloan is worth more than that
kb58
| posted on 12/3/06 at 01:07 AM |
Joao
You mean dry-sump.
And its book -
Jon Ison
| posted on 12/3/06 at 10:44 AM |
There is little (very little) too choose between the front running class A RGB's (Busas, ZX12's) and the front running class C RGB's
(919 blades).
Toady1
| posted on 12/3/06 at 12:18 PM |
so basically are we saying that its worth the extra couple of grand to go for the busa powered cars or not?
does anyone know the performance figures of 0-100 or 1/4 mile for the blade and busa engines in a bec weighing approx 450kgs?
OX
| posted on 12/3/06 at 12:36 PM |
no i think for a long time people have thought that the busa is to expensive for the little extra that you get ,on paper if you look at lap times and
weight it might not look like its worth it but its the raw power that is felt that makes me think its worth the extra.you need to get a ride in one to
see for your self
| posted on 12/3/06 at 01:06 PM |
Go for the ZX12R and it won't cost you a couple of grand more. Just a few hundred more for the same performance as a Busa
| posted on 12/3/06 at 01:11 PM |
buy the blade one, to see if you like BECs, and than as with all things, you will want more power - that is when you pull out ya wallet!
My old crossflow lump felt lively on the roads but underpowered on track, thats why im putting a zx9 in. If all goes well, i'll then rebuild the
full car with a zx12.
Toady1
| posted on 12/3/06 at 04:20 PM |
yeah thats how im thinking. I think i will initially go for a blade engined car, and go for a bigger engine if it comes to it, but as OX says, i need
to go for a ride in some first!lol!
ChrisGamlin
| posted on 13/3/06 at 08:00 PM |
Ive driven a busa on track several times(as well as my own blade / R1 car) and although the busa is cetainly quicker than the blade, as others have
said its not miles different. The main place you loose out it high speed acceleration, coming out of slow corners up to say 70-80mph you wouldnt lose
much to a busa car, but after that it will stretch its legs and carry on accelerating as hard well past 100mph, whereas the blade acceleration tends
to tail off a bit at higher speeds where outright power is more important than power/weight due to all the drag you need to overcome. As an example of
on track performance, my mate's Megabusa would just about hit the limiter in 6th up the Kemmel straight at Spa (after Eau Rouge) so touching
125-130mph, compared to ~115-120mph for my blade which wouldnt hit the limiter.
I have to say though that the R1 bridges the gap quite well so for a few hundred extra Id seriously consider that option (as well as the ZX12).
Ive not had chance to compare mine against my mate's recently (as his busa now has a turbo) but I drove his car and another almost identical
Westie with an R1 engine in it on the same day at Llandow a year or so ago, and the pull of the R1 isnt far off. I think above 100mph the busa would
still have an advantage but below that there is a slight difference, but not very much.
If you work out the power / weights of all three that backs up the feeling because the R1 car is far closer to busa power to weight than it is to
blade p/w once you factor in the 30kg weight penalty of the busa / ZX12.
Chris
Toady1
| posted on 13/3/06 at 08:25 PM |
cheers chris, a very helpful answer!
GeorgeL
| posted on 19/4/06 at 05:32 PM |
Does anyone actually have any performance stats. Not really interested in 0 - 60, but what about 0 - 100 and 1/4?
G
