Jubal
posted on 9/4/06 at 04:26 PM |
Blade clutch question
Due to clutch slip around 7-9k revs I replaced the springs and plates in my blade (RRX) clutch today. I noticed that the kit I was supplied with by
Fluke Motorsport (made by barnett) was subtly different to the one I took out.
The one I took out had an outer friction plate (nearest the cover) that was slightly thicker than the regular plates but the barnett kit just had all
the friction plates the same apart from the inner plate.
Anyway, as I was trapped in the garage by a thunderstorm I took a flyer and bolted the thing up, filled it with oil and as soon as the sun came out I
went for a spin.
As far as I can tell I seem to have cured the clutch slip but the fact the kit had no special outer plate is bothering me. Should I care? Advice
appreciated.
ChrisGamlin
posted on 9/4/06 at 07:00 PM |
As long as you set the final plate so it sits in the special recesses in the basket rather than sliding down the channels like the othe plates do, it
shouldnt be a problem. I dont actually recall using a different plate on the outer anyway, and also used to throw away the anti squeal shim on the
inner plate and put in a standard plate instead so they were all the same.
Jubal
posted on 9/4/06 at 07:28 PM |
Thanks Chris. That's exactly what I wanted to hear.
