JoaoCaldeira
| posted on 23/4/06 at 09:41 AM |
2003 R1: Ignition plug
Hi all.
The wiring diagram, IIRC, refers to a 2 wire plug, but could it be a red 4 wire plug?
How is it wired?
Thanks again,
Joao Caldeira
[Edited on 06/4/23 by JoaoCaldeira]
MartinDB
| posted on 23/4/06 at 10:19 AM |
There are 6 connections on the ignition switch.
4 are via the red plug including 1 from the light switch and 1 to the sidelight fuse, I can't remember the other 2, and my Haynes manual's
on site.
The other 2, red & brown/blue via a white connector are the switched 12v.
Martin.
speed8
| posted on 23/4/06 at 02:44 PM |
6???
I only had 5, 3 on a red plug and 2 on a white? plug... iirc
1 is the sidelights 2 short together from ECU to cutoff relay/clutch switch
The other 2 are the switched 12V.
