ceebmoj
posted on 6/5/03 at 08:08 AM |
drive shaft
Hi I have been thinking about going the bike engine route. I have however noticed that a lot of builders split there drive shaft so a reveres box can
be fitted. My question is if you do not fit a reverse box is it of to use a single drive shaft or is it best to split it with some bearings and a
connector in the middle.
ChrisGamlin
posted on 6/5/03 at 09:42 AM |
You'll definitely need a two-piece driveshaft with a centre bearing, the distance between the bike output shaft and the diff on a conventional
Locost is far too big to allow the use of a single piece driveshaft unless it was about 8" diameter!
Chris
ceebmoj
posted on 6/5/03 at 10:19 AM |
how come you dont need a two piece draive shaft on a conventional engined car as the book sugests. is it just a mater of the hi rpms
ChrisGamlin
posted on 6/5/03 at 10:23 AM |
Nope, if you have the same diff, the RPM of the driveshaft isnt any different in a BEC compared to any other engine, but if you think about it, in a
normal car install, you have a nice long gearbox that stretches half way down the tunnel, so the propshaft only goes from the end of this to the diff.
On a BEC, you don't have this gearbox in the middle as its all integrated into the engine casing, so the prop has to reach from the engine bay
right the way back to the diff, about twice as far.
Chris
ceebmoj
posted on 6/5/03 at 11:17 AM |
ok thanks for the info
