Bitten hero
posted on 31/7/06 at 09:05 PM |
HELP NEEDED- ENGINE INFO
Hi all,
Would it be safe to turn over my engine without the regulator /rectifier connected?? as it is missing and i need to get one!! thanks gary.
raccoonradar
posted on 31/7/06 at 09:19 PM |
Remove the drive belt from the alternator if unsure, sould be ok for stort time just don't drive it with out the regulator /rectifier on it
will fry your battery & blow bulbs ect
ChrisGamlin
posted on 31/7/06 at 09:23 PM |
This isnt boat-anchor world you know There isnt a drive belt from the alternator as its on the end of the crank
Why do you want to turn it over out of interest?
raccoonradar
posted on 31/7/06 at 09:26 PM |
I see, its a bike engine then !
![](/images//smilies/bigsmile.gif)
smart51
The generator / alternator will probably be OK if electrically disconnected. At least it should be. The rest of the engine will be just fine but it
will drain the battery.
Without the regulator fitted, you'll be runnin purely off the battery. There's no chance of blowing the bulbs. The alternator will be
spinning and generating voltage but without any connections, there will be no current.
I wouldn't run it for any length of time without the regulator fitted but if you want to see if the engine works then you should be OK.
ChrisGamlin
posted on 31/7/06 at 09:31 PM |
The clue is in the forum title
raccoonradar
posted on 31/7/06 at 09:42 PM |
Oh I see again, Will have to change my beer goggles ![](/images//smilies/bigsmile.gif) ![](/images//smilies/bigsmile.gif)
posted on 31/7/06 at 10:09 PM |
i ran mine a few times recently with no reg/rec fitted, seems to work just fine.
yorkshire-engines
posted on 1/8/06 at 03:28 PM |
iv got a r1 reg you can have for £30
what happened to the x11 engine
Bitten hero
posted on 1/8/06 at 06:46 PM |
Hi all
Just to clarify i only want to see if the engine is a hiss one or not once and for all ie check for sparks etc and its not in car just engine box
etc-its a honda 1100 from a x11
[Edited on 1/8/06 by Bitten hero]
