Hayabusa clutch
Ok peeps IM having a few problems with this. Decided to uprate springs and fit one of these anti ramp devices. Choice of the TTS/extreme billet center
or this; http://www.hayabusacentral.co.uk/shop/product.asp?idproduct=109&source=thumb
Went for the latter on the grounds it was half the price and also came with springs. However I cant see where exactly its meant to fit.
Have removed the clutch pressure plate and exposed the cam set. Now the ring looks like it should fit over the three pronged cam in the center, but to
do this means removing all six stand offs. So Ive done this, put the ring in place and now the stand offs foul the edge of the ring.
Am I missing something? Should it go deeper into the clutch? If this is the case I need to remove the clutch sleeve hub nut and this has been peened.
So how the hell do I remove this? If Id gone for the billet options then this nut would have to be removed, but I cant see how to do this without
damaging threads.
Help!
[Edited on 3/9/06 by iiyama]
