phil_far
posted on 12/9/06 at 03:38 PM |
FireBlade Carb Re-Jetting
I am re-jetting my FireBlade engine. I am using a Stuart Taylor exhaust and a DynoJet Stage 1 Kit with K&N filters (individual type). Which
is the correct jet size from your experience? The instruction say sto go 'four stages up'
Confused!!!!
Philip
ChrisGamlin
posted on 12/9/06 at 06:51 PM |
From memory, try starting at ~128 main jets, I think thats what Ian Gray fitted to my carbs when he did the conversion for me.
Bladerunner
posted on 12/9/06 at 08:31 PM |
Carbs
Memory of the other guy must be off, size is 28 but you must block off the emulsifyining tube. Give Ian a ring at Stuart Taylor.
bigrich
posted on 12/9/06 at 09:58 PM |
128 main jet 893cc blade 132 main jet 919cc block main air jet (tall brass tube inline with needle and needle on clip 2
all as per tts jet kit for car applications with individual filters
would recommed final set up on a dyno for optimum running but is a good starting point
phil_far
posted on 13/9/06 at 04:00 PM |
Thanks guys.....great help!!!
Regards
Philip
ChrisGamlin
posted on 13/9/06 at 07:14 PM |
Errrr........why?
phil_far
posted on 15/9/06 at 03:22 PM |
My instructions do not tell you to block teh main air jets and I do not have a 128 but 133 is the smallest...mine is an 893cc engine
My kit is from Dynojet
Philip
Coose
posted on 15/9/06 at 03:53 PM |
Size 28 main jets???
Block off the emulsion tube???
Funniest thing I've heard all day.....
Spin 'er off Well...
ChrisGamlin
posted on 15/9/06 at 04:55 PM |
I was waiting for him to explain himself after seemingly dismissing my comment
