MK9R
| posted on 21/5/03 at 11:54 AM |
pre 1995
If i state that my engine is 1994 (new engine number if re conditioned) will i not need to have a cat on it, and will it get through emmisions without
the lamda/carb thingy?
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Macca
| posted on 21/5/03 at 12:22 PM |
You mean sort of lie?
Don't understand the new engine number bit, would you be talking about a No. that the reconditioner would apply thats just for their
reference.So you would end up with no manufactures No.?
Is that legal?
If you are going as far as changing No.s there must be an easier way????
Col.
benedict
| posted on 21/5/03 at 01:23 PM |
If you state that your engine was manufactured pre-95 then you will need some sort of documentary evidence to back this up. Some centres allow a bit
of common sense in that if it's an engine that hasn't been used since then then they'll let it go, but others still want the
documentary evidence.
ISTR hearing some centres wanting something concrete from the manufacturer, while others are happy with the codes from the Haynes Manual.
I'm pretty certain that if you don't have a proper engine number or if it's "come off" you'll be tested to the cat
standard.
As ever with SVA stuff the fine details are as variable as there are many testers.
If you're going to a "friendly" centre like Notts or Derby, I'd suggest giving them a ring if you want to clear anything
up.
Ben
