xico_ze54
posted on 6/10/06 at 03:44 PM |
need some help
somebody can tell me where I can buy these 2 kind of pieces?
a. clutch slave cylinder same model showed on pic.
b. sprocket adapter to fit '94 CBR1000 shaft with Sierra flange.
thks
Amadeu
rayward
posted on 6/10/06 at 03:57 PM |
for the prop adapter try Z-cars
link
Ray
TimC
posted on 6/10/06 at 05:06 PM |
Any of the UK based kit manufacturers should be able to sort the prop adaptor.
As for the clutch cylinder, is that the standard CBR1000 unit?
Syd Bridge
posted on 6/10/06 at 05:38 PM |
Clutch slave looks like an ali copy of a Mini part. Or it's silver coloured zinc passivated, which is more likely. Also found on early Metros
with hydraulic clutch. The older Mini slaves are cheaper than the later Verto type. Sherpas also had something similar.
Syd.
TimC
posted on 6/10/06 at 07:59 PM |
quote: Originally posted by CaLviNx
Hi
That actual adapter looks like the one that Attitude Roadsters
and the slave cyclinder looks like a generic one with a custom bracket.
Lyndsey at Attitude has built many a 7-type. Knows his sh*t!
xico_ze54
posted on 7/10/06 at 06:47 PM |
Thanks all for helping.
That pic isn't my CBR's. I just showed it to see an example of how it could be (clutch cyl.).
The pic I attach now shows my engine. the clutch cyl. is enhanced in red, and the sprocket cover is enhanced in yellow and transparent .
I think the original cyl. doesn't fit together with the adapter, just because there's no room.
what you think?
clanger
posted on 8/10/06 at 06:32 PM |
Hi
Thanks for the ringining endorsement Tim.
If you need any advice or assistance with the new build just get in touch.
By the way, for the info of all you BEC fans my new website is up & running
Attitude Roadsters
posted on 8/10/06 at 08:06 PM |
These are Mini ones Verto and
pre-verto .It looks like one of them with a bracket adaptor to
fit it. If the one already on there is not too deep the dish on the prop adaptor may clear it, I'd be tempted to order one and try it for size
as you'll need one eventually anyway.
